Hello fellow forumers'
I am trying desperately to download the above firmware upgrade, but there appears to be a problem with the site. Can anyone help????:smileysad:
Seems to be working ok.
Optical drive problem?
Twisted Rizzla - I can get to the point of the download, but then it just keeps coming up with an error message to say that the download has failed. It then gives another message to say retry cancel etc, but when hitting retry it just hangs!!!!!
Are you able to download??
I'll find out...
Yes it downloads OK at this end. If you want it let me have an email address and your model, just to be on the safe side – file size 811Kb.
Works ok for me too.
Rich
Very kind of you. I have a VGN-A497XP and need the Optical device firmware (for device as stated above). My email address is [email protected]
Sent - check your email.
Rich
Thanks very much - just waiting for it to come though.:smileyhappy:
No problem Silu, I hope that it solves whatever problem you have with the optical drive:smileyhappy:
