Entering the BIOS at power-up
LesleyPark
I have a Vaio PCG-FX103 laptop, on which I am going to swap out the hard drive (10GB to 60GB). This means I will have to re-install the OS (which has been upgraded to Win XP Home), which in turn means booting from a CD rather than the hard drive.
How do I get into the BIOS setup program at power-up, so I can set it to boot from the CD rather than from the hard drive?
Thanks in advance
Lesley Park
1 REPLY 1
William
Ibelieve the default is to boot from CD before HDD but if its not pressing "F2" repeatedly at switch on gets you into the bios.
