Was trying to setup my SkyBroadband and batter on my old Viao was holding less and less charge I've got a PCG-FX605. And it shutdown in less than 2 minutes...
When I tried to switch it on again, the amber light that flashes (next to HD lite etc.,) was flashing RED rather than amber and Laptop wont switch on 😞
HELP...
Does the Laptop need the battery to work? As it does n't want to switch on with just the power cord attached....
Reading this from other PC...
And if it is the battery how do I find the part number and cost? Would anyone recommend somewhere perhaps...
