Hello my dear colleages.
I have been using my SONY VAIO VGN-N 11 S/W since January 2007.
I don't know what happend, but my battery is down 😞
Now, it's enough only for 20 minutes normal of work.
Don't know what to do.
Sony is a good brand and I just can't get what happend with
is a battery in a just 2 years.
What sould I do to repair this one or get a new battery or just make it work normally?
Hi eternalko,
welcome to Club VAIO..
A simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if you can try another battery in your Vaio..
At a guess I would suspect the battery rather than a hardware problem, hopefully you can check this before purchasing a replacement..:smileysad:
