I have a new JS1E all in one and right out of the box it has a problem starting the wireless drivers (code 10).
When I power up or restart I often have to disable then enable it from the device drivers and even then it takes a few times for it to start. And other times it starts right up. If the machine goes into sleep mode then I will have to reboot to get the drivers working again.
Its quite infuriating - has anyone else had experience of this or can suggest a fix? The wireless device is an Atheros 928x and I running 32 bit Vista with all the latest updates installed.
