RE-EDITED as I have found the solution...
PROBLEM:
After using Quicktime7 (or above) for watching video, the INTEL MATRIX STORAGE application shows an error in RAID-0, that appears to be unfixable without removing the partition and completely re-installing from scratch.
Thank you so much, I have the VGN-AR61S and was having the same problem
Thought I would have to send it off to have the hard drive replaced (after having it two day) but your fix worked a treat.
Hi DobbyDob,
welcome to Club Vaio..
Have installed the SATA Driver Update 7.5.0.1017 for your vaio.?
You can download the update using the following link: SATA Driver Update 7.5.0.1017
Hello, i have model Vaio vgn-ar31s, and i have huge problem with my raid volume0, in last 4 days i recovered my system about 8 times... in my computer i can see message that, one of my raid volume fail, backup data imediatly! i had the same problem when i just bought this notebook, in garanty they helped me to fix that problem, with raid configuration, and it helped, but now if i do the same with that raid configuration, it helps just for 1 day, till i want to write something in my hard drive, my notebook stop respoding, and when i restart it, i got that message about my volume problem... Sony utilities cant find the problem it shows that everything is ok, i checked several time, just if i check with windows chkdsk when pass 52 % its stops respoding, and i have to swich off pc, i tryed all erase&wipe types, nothing hepls:(( garanty is 2 month over.. pls help me, what i have to do? buy new HDD? Sorry for my english im from Lithuania, live now in Germany.
Hi sabotaz and welcome to Club Vaio.
It sounds like one drive needs replacement.
Even though you are out of the warranty period, I would contact Sony Support as this is a known issue and you did contact them about it when still within the warranty period. It is worth a try.
Did you make a set of Recovery Discs?
