AR buttons do not work
tungakantarci
Hello,
Sometimes the s1, s2, volume, eject, and mute buttons on the left panel does not work.
If I restart the computer they always work fine.
But then they dont work when a specific thing happens.
I am not sure about that specific thing. It can be hibernation or standby... cant locate the problem yet.
What may be the problem causing the buttons dont work?
1 REPLY 1
Thalamus.
Champion
Hi tunga kantarci,
does this problem only appear after restarting from hibernate or stanby.?
Have you tried downloading the Preinstalled Utilities from Vaio-Link, use the following link then select your model in the drop down list to download the update: Sony Support Downloads
Once downloaded extract the files and then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your Vaio.
You may have to do this more than once..:smileywink:
