Hi there
As both your TV and Bluray system support HDMI ARC, try connecting a HDMI cable from the HDMI 1 (ARC) port on the TV to the HDMI out (ARC) port on the bluray player instead of using Optical. Then test this.
That might be the issue.
You dont need the Optical cable at all
As you have connected the HDMI cable to the ARC ports. This might be giving a conflict. Therefore disconnect that optical cable, and just double check your settings on the NF720 so that your audio is going via HDMI.
ARC = Audio Return Channel.
If you have an older (or cheap generic) HDMI cable, might be best to replace it, HDMI 1.4a cable (would be good).
Thinking about it, replacing the HDMI cable wouldnt be a bad thing - and also might be connected to your problem (potential HDMI handshake issue). Best to rule it out anyhow.
A 2metre Pro Gold Red(1.4a) on Amazon is only £8 as well - so they arnt expensive at all.
not sure of your model tv but try pressing options on your remote, scroll to speakers and set from tv to audio system and try this ( if it allows you to)
never had a problem like that, having said that you could try as quinnicus said and use the latest cable, i use one of these-
very good cable for the money, perhaps ditch the optical in favour of ARC see if that works for you?
