Partilhe a sua experiência!
Solucionado! Ir para a Solução.
@JSIDNEY1974 wrote:
Can anybody out there help me! A few years ago I purchased a Sony 3D TV Model as subject title. I am now looking to purchase a USB Dongle to insert into the telly that will connect my TV to my WI - FI connection!! Does it have to be a Sony Dongle or can it be a more cost effective universal dongle. If anybody is out there that could give me some sensible and decent advice & any recommendations that would be great!!
Kind Regards
JAMES SIDNEY.
Hi James,
welcome to the Sony User Community Forum..:smileyhappy:
Unfortunately a universal USB dongle will not work with your Bravia in order to connect wirelessly you'll need to purchase the UWA-BR100..
Or alternatively use a set of homeplugs, something like the TP-Link HomePlug AV Ethernet Adapter Starter Kit,(example only as you may find cheaper alternatives) allows you to share data between your router & the device which is connected to the other homeplug via your home's existing AC power sockets..
Kind Regards
JAMES SIDNEY.
Hi James,
Hi there
Only the Sony USB Wifi Dongle will work. The model you are after is - UWA-BR100
http://www.sony.co.uk/product/tpa-other-tv-accessories/uwa-br100
Amazon however sell it a little cheaper:
www.amazon.co.uk/Sony-UWABR100-Bringing-Wireless-Internet/dp/B0036XX4G0/
EDIT: Beat me to it Thalamus
Hi there
@JSIDNEY1974 wrote:
I have seen the UWA - BR100 for £50 on Amazon, is that about the going rate.?!
Unfortunately that is the going rate. It was much higher a while ago though!
@JSIDNEY1974 wrote:
I may purchase one of these. I do however have a 15m long internet cable! That will connect from my router into the back of the TV would this work!!?? As a temporary measure!! Thanks for your time and help it is appreciated!!
Yep, that will work. However, if at all possible, I would try and make it a more perminant solution instead of temporary. A cabled (wired) solution is always better than wireless. Thalamus suggestion of the homeplugs is worth consideration.
@JSIDNEY1974 wrote:
Finally one more question I have connected my Sony 3D telly ref KDL40HX803U, To a Sony DVD Recorder Ref HXD 870! It does work and we can play back previous recordings! However, when we come to record programs on the timer recording list no programs show?! Can you advise how to get the program guide back up!?
Another forum member will hopefully assist you on that one (I dont know!).
Cheers.
My mum has the wireless dongle and has had very little trouble at all. Once I had to use the break away cable attachment (included) to move it away from the TV for awhile. Other than that, she is using her TV with the router in another room with no problems.
I have also heard all the stories and reviews too. As I was the one that bought the dongle for her (for her birthday). So I was apprehensive at first. But all is good.
For me - I have 1 network cable from my router, linking to a gigabit switch at my TV (I have 4 networked devices at the TV end)
_______________
Option 1
If your router and TV is in the same room, I really cannot see problems with a wireless dongle. If you purchase the dongle online, you do have a 7 day distance selling legislation. (Cost = Approx £52)
Option 2
If your router is in the same room, you can get a long network lead and "hook" it round the skirting boards (or somewhere equally out of the way) and connect the TV to the router (Cost = Approx £6)
Option 3
If you have a spare power point near your router and another spare one near your TV (NOT on a powerboard though), you might consider Homeplugs (Cost = Approx £20 +)
________________
So the question comes down to - Where is your router in relation to TV?
Same room = Option 2 if possible, Option 1 would work as well.
Different rooms = Option 3 preferred, Option 1 only if you have thin walls (ie not stone/brick)
Hi there
As far as I see it, you really only got one option....and that is Homeplugs.
So we have left is homeplugs. There are a couple of varieties. You need 2 of them (ie a pair). One for the TV side of things, and one on the routers side. Dont worry, the packs include 2. The other thing with Homeplugs is, is that they need to be on the same electrical circuit. Hard to know for most people. But in general, power points are normally on the same circuit.
As always - If you purchase over the internet, you have a 7 days distance selling legislation, where you can return the product.
Anyway, hope that helps you.
And yes, I do like this forum too
Cheers.
