Sony xperia ray stuck on Sony logo....
lucky7
Hi! I'm using xperia ray.Last week I replaced my display and touch set  to genuine set because ohf touchpad problem.Afterthat I tried to update my phone by using sony pc companion but it wasn't success. It doesn't boot stuck on sony logo. Can anyone  please help me? Sorry for my poor English.
lucky7
Thanks #uliwooly it solved. I replace my display and touch set and now works fine. Thaks Sony Support forum and #uliwooly.
Spoiler
Spoiler
Spoiler
:smileysmileywink::smileyztele::smileyyahoo:
11 REPLIES 11
Uliwooly
@lucky7
Do you get an error with PCC?
lucky7
it says cannot complete the update. software doesn't available to your device.
Tags (1)
Uliwooly
@lucky7'
have you unlocked the bootloader?
lucky7
I don't know how to unlock the bootloader. Please can you tell me how to do it?
Uliwooly
@lucky7
You don't have to, I was wondering if you did, you could use flashtool to repair the phone.
CameronT
Champion
Hi @lucky7,
Welcome to the community.
Updating the phone is not going to help in this situation. You may have to run a full software repair.
EDIT: My mistake, the Xperia Ray is no longer supported by the Xperia Companion or PC Companion software. Please follow @uliwooly's advice on this one Slightly_smiling_Face
Uliwooly
lucky7
I downgrade my phone using flashtool but nothing happened my friend . Afterthat it was stuck in sony ericson logo .
Uliwooly
@lucky7
I'm sorry to hear that, you might want to contact Sony directly >>> Local support
