K800i and internet connection.
Not applicable
How can I disable the internet connection since the phone switches onto internet at random when I do not what to go on line and I am getting unneccessary charges
Jeff
Enthusiast
You can delete the account in the Settings > Connectivity > Internet Settings menu. If you delete the account there is no problem accidentally connecting
2 REPLIES 2
Jeff
Enthusiast
Not applicable
Dear Jeff,
Thanks for the answer and I have (I think) deleted the account setting.  Only time will tell.
John
