Deleting an individual call - Call Log?
Not applicable
Can anyone tell me how to delete an individual call or text message on my new Sony Ericsson Xperia Mini (which I love by the way)? Would really appreciate help in finding some sort of Call Log which I can edit. Thank you.
higwayman
Go to the Call List,
Long Press on the number you called.
Sreen pop out will gave you a selection to delete :smileygrin:
4 REPLIES 4
higwayman
Not applicable
Thank you so much, that is brilliant. Have just tried it and it worked. Can you now tell me how to delete a 'sent' message too? I guessed it might be the same idea but cannot seem to find my 'sent' messages.
higwayman
Go to Messaging
Long press on any message
Pop up to select
To select several for delete, press left MENU button ( 4 small little squares), pop up to select preferred action Slightly_smiling_Face
Not applicable
Thank you Higwayman, very useful. I'm all sorted now - going to go and play with my new toy some more.
