I bought a Sony xperia M dual c2005 from Oman after using 2 days it's battery draining so fast like watch time. What is the problem. Hardware or software? I checked this phone hardware by this code *#*#7378423#*#*. No hardware found. Is there any hidden hardware problem. Or software problem....? Plz give me a best solution.
Root the phone to be able to move apps to SD...how?
If i root my phone, Will phone be face any hardware problem? Can i unroot again? If i unroot again, can i official update by OTA or Pc companion?
As long as you do not unlock bootloader,you should be able to root and unroot without problems.But your warranty could be gone.
Understood Thank u.
Dear, how can i solve too much brightness in minimum of display brightness in drak?
Don't you have the adapt to light conditions option?
My phone have adapt to light condition. But minimum brightness hit on my eye but Sp, L's Minimum brightness not hit on eye....
How can i root without unlock bootloader? I want to root for moving apps to sd card. My phone's android version 4.3 now.
