When you add a new contact, do you choose to save it as a local contact or to any account such as Google? Have you checked so the filter function of your contact is not disabling local contacts etc? You can see the filter settings if you go to Contacts > Menu button (three dots) > Filter > Check under "Display contacts".
I'm glad to hear that it's working now, anytime!
