M2 and mw600 bluetooth problem
johndan
Hi to all,
I have the mw600 bluetooth headshet with the m2 phone.
Every time i am trying to listen music it plays for a few seconds stops for half a second and continues to play and so on.
I have test it with several application and sony walkman appl but still the same problem.
I have done anything i can think of (reset to factory etc.) but the issue remains.
I have test the head shet in another phone (Samsung) and plays perfectly.
Anyone else has this issue?
Uliwooly
6 REPLIES 6
Uliwooly
You should contact your local Xperia Care
http://support.sonymobile.com/global-en/contactUs/
Uliwooly
johndan
Yes....in safe mode it works normally.so I have to reset everything again and test Appl by Appl to see which one cracks my Bluetooth.
Thank you very much
Uliwooly
Anytime, keep us updated
johndan
Seems like i didnt reset it correctly..So in Safe mode it worked correctly.
After that i have unistalled everything and works.
Looks like one of the downloaded appls has the problem.
Uliwooly
Indeed
