Camera frozen and no way to get it work D:
xLobito
Hello everyone...
Just the title say, I was taking pictures in my Xperia M2 (Eagle Rex) in differents modes, such as Manual, Auto, etc and when I try again, the buttons on the bottom disappared and then a message says "The Camera not working - Wait/Force close". I try to put "Wait" firstly, but, no response shows up and the message shows up again, now I put "Force close", but, no response of it since I put it.
Any ideas? 😧
Thanks.
profile.country.RO.title
_alexdon_
5 REPLIES 5
_alexdon_
Settings-apps-all-camera,force stop and clear data.Restart.
alexdon
xLobito
It's stuck in the Camera application... I can't use the "Home button" to show the background and then go to Settings and bla... I can't literally move a finger to get it work.
:'c.
Thanks again
_alexdon_
xLobito
Well, I use your guidance posted here. And force the shutdown on my own device. I left then a few minutes to get it cold, and after that I turn on my device and everything goes well until now.
Thanks for everything!
Regards!
_alexdon_
Great,well done.
alexdon
