HowTo Video: Mobile High-Definition Link for BRAVIA
jaylward
1,509  Views
MHL- Mobile High-Definition Link allows you to link your compatible Android smartphone or tablet device directly to your BRAVIA TV via an MHL cable allowing you to display the contents of your device on the big screen.
This video shows you this simple connection process.
