Hello all, this is my first post so here goes, I recently purchased the Sony KDL55W829 and the Soundstage HT-XT1. My problem is no matter what I do I cant get the television remote to control the soundstage volume. I have a Ps4, Lg Blu ray player & sky tv plugged into the 3 'in' hdmi ports, the 1 out I have plugged into hdmi 2 of the television which is the ARC port. The HDMI cable I am using is a v 1.4 cable ( http://www.amazon.co.uk/TEEPEE-ONLINE%C2%AE-ETHERNET-LIFETIME-WARRANTY/dp/B00D6F2MKW/ref=sr_1_2?ie=U... ) and I can't find any information online about what I'm doing wrong. I have checked the troubleshooting guides and manuals etc but to no avail. Any help would be greatly appreciated!!
Hi BobbMc
I am also out of ideas as well. The only thing left to suggest is to contact either your retailer for an exchange, or contact Sony Support : HERE
Unfortunately thats all I can suggest to be honest. Good luck with everything, and please post back if/when you get a resolution - id be interested to know.
Hi there
From your description, everything looks right:
Firstly, Do you get audio from the XT1 when watching TV? If so, that means things are working correctly. If not, suggest a new cable (you never know)
In regards to the single remote control:
Hope this helps
PS: Welcome to the Forums
Hello, and thanks for the quick reply,
Yes I am getting sound from the xt1 via the HDMI cable.
In regards to the bravia sync, when i go to the bravia sync device list, the Playstation comes up, but the xt1 does not, when i choose 'ENABLE' and it comes up with controllable devices listed it does not show the xt1 on the list.
I have changed the volume to variable, as i didnt know about this, no difference with the sound.
The XT1 has 'Control for Hdmi' set to on.
One thing I've noticed (not sure if it relevant) is on the sound menu, when i highlight the Speakers option I'm given the choice of TV speakers, or Audio system. When i choose audio system it comes up with 'Tv speakers active due to audio system communication failure'
Hi there
Sounds like a communications error - especially with TV speakers active due to......
Sometimes its fixed by simply switching EVERYTHING off from the powerpoint on the wall. Other times, its remove HDMI cable, turn it all off and on again, then replug cable back in.
Other times, its a replacement of HDMI cable.
Give that a go firstly anyhow.
Apologies for not getting back quicker, I ordered a new hdmi cable,so was waiting for that to arrive. It hasn't solved the issue! Unplugged the television and soundstage, left it for 15mins, unplugged the hdmi cable, the re-plugged in the television and soundstage, plugged in the new hdmi cable, no difference in regards to control of the volume!! Not sure what to do now...
Hi BobbMc
hi mate i have the same tv and ht-xt1 use hdmi port 1 which is the arc port hope this helps i find the sound is awful from sky and not loud at all
