Looking to buy
Sony BDV-N7200W
but was wondering if I can connect PS4 and Xbox one to it or does it need connected to my tv then run an optical cable from tv to unit , thanks
@Dysama3 wrote:Looking to buy
Sony BDV-N7200W
Hi @Dysama3
I see it has two inputs (not 4K) so you could connect your PS4 and Xbox if you want. You certainly don’t need an optical cable. Simply connect a HDMI lead to your TV’s HDMI ARC connection so you get the sound from your TV on the BDV-N7200W. Your choice. If you connect your PS4 and/or Xbox direct to the TV then you can get sound via HDMI ARC also to the BDV-N7200W set to Input TV.
