I am sorry to say , but Im not happy with my headphones. Great sound and comfortable, but unfortunately theres a bad clattering sound of the plastic parts. This happens every time I use them when Im out walking.
Ive turned them in for reparation, but the problem is still there.
I will try to improve, maybee glue on, a thin , soft fabric ...: (
Hi @tanjabrekka
Are you sure that this noise is caused by the plastic parts, not a software issue?
You can eliminate this possibility by updating its firmware using the app, resetting and initializing the headset.
Update firmware: https://www.sony.co.uk/electronics/support/wireless-headphones-bluetooth-headphones/wh-1000xm4/softw...
Reset: https://helpguide.sony.net/mdr/wh1000xm4/v1/en/contents/TP0002752743.html
Initialize: https://helpguide.sony.net/mdr/wh1000xm4/v1/en/contents/TP0002752746.html
