Hello
I hear this is possible with some fiddling. Can anyone help please
Hi there, is it the Game Civ 2 you are trying to install?
I don't think you can install Civ 2 Classic on a Windows 7 OS.
Which version of Windows 7 do you have? If you have indows 7 Professional or higher you can try using
Windows Virtual PC and running the game in XP mode.
If not then you could try using other virtualization software such as VMware.
(I don't have the game though so can't guarantee it will work)
