Laptop running slow
profile.country.en_GB.title
CSK280
Laptop running slow
I have a Sony Vaio VPCCB3P1E
Intel i5 2.4GHz
Memory 6GB
Windows 7 SP1
VCSystemTray.exe using 50% CPU and 50% memory
Any ideas as to repair?
2 REPLIES 2
Pavvy8
laptop seems pretty fast- first thing that comes to mind is to format it and just start fresh ....if its still really slow after the format then you may have to start looking at hard drive
Nobody-in-particular
Contributor
I wouldn't recommend formatting because in doing this you cold inadvertently erase the recovery partition.
You could try downloading and running something like Ccleaner to see if that helps.
