Hey there,
sorry if i publish here but there is no spoecific thread or forum for this issue.
I'm trying to register my ps4 @ https://www.sony.co.uk/mysony/product/register
but it won't recognise my product cuh-2016a or allow me to enter the full serial number.
Thanks
Hi there
Does your serial number have a 03 in it at the start?
I believe if you leave that out then the registration should work.
cheers
You simply need to enter "PlayStation 4" which should allow you to register your product.
Peter
yes I selected playstion 4 but when I try to enter the serial number I can't enter all the digits
Hi there
cheers
Yes it does have the 03. I'll try, thanks
No worries
Good luck and keep us posted!
Hi - i have tried all the above but still cannot progress to register my PS4
BTW the Model#=>CUH-1116A
I am having the same issue. I type in my model number beginning with CUH and it disappears when I got to click register.
