using the reader abroad...
profile.country.en_IE.title
grosull17
to charge the reader you have to plug it into a laptop or computer, right? what about when you want to buy more books, do you have to download the software each time you want to buy a book? i'm only asking because im going travelling & im not sure if i should take the reader with me or not....
profile.country.en_GB.title
specialist-convergence
Hi, if you wish to purchase eBooks you will need at least Adobe Digital Editions, this is a small program, however the DRM requires a link between the store, your PC and the reader, this would not be easy on the move, unless you are using a laptop.  it would be best to fill the Reader before you go on your travels.
2 REPLIES 2
loukemper
be aware that if the reader needs repairs and is still under warranty, take it back to the country you bought it, as the warranty is not honoured by any other country.
