PRS-T1 WIFI does not work
profile.country.nl_NL.title
Quintus5
I just got a PRS-T1 but the wifi connection failes:
  • Scan does show my access point as excelent.
  • After I enter the password, it tries to connect every minute, but immidately says: connection broken.
  • My smartphone connects successfully with the samen password.
Has anyone an idea what the problem might be?
Quintus5
The problem has been solved.
It was caused by a MAC filter in the router. After adjusting the MAC filter the wifi connection worked good.
2 REPLIES 2
Quintus5
profile.country.en_GB.title
davide273
I have the same problem. Can you give any details on how the MAC filter should be adjusted?
