My PRS 505 will not power up?
profile.country.en_GB.title
dave-stead
For some reason I can't get my PRS 505 to turn on.  I have charged it up with a wall charger but still get nothing.  Can anyone help???
carpetmojo
Do you have a "soft" reset facility ? Sorry, I don't know the 505, but that's what you'ld try first on the 6/350 line.
A hard reset is also available, but you will lose all you have loaded onto the device - but check your manualregarding both options  [online (your PC)  is usually fuller & more detailed.]
If the soft does nothing, and you don't fancy a hard reset, I'd contact Sony Support - 'cos then it sounds like a
duff battery, or charger. I take it you've used the charger before successfully ?
Hope this helps...:smileyplain:
2 REPLIES 2
carpetmojo
wolfman42
HI,
DID YOU GET YOUR PRS 505 WORKING AGAIN ?
BECAUSE I HAVE ONE AND THE SCREEN IS CRACKED.
I WAS WONDERING IF YOU HAVE NOT GOT YOURS FIXED AND ARE SELLING IT FOR REPAIRS I MIGHT BE ABLE TO MAKE YOU AN OFFER FOR IT SO I CAN USE YOUR SCREEN ON MY PRS 505 E READER.:smileyhappy:
