I seem to be unable to remove the micro sd card from my new PRS T1. Is there any easy way to eject this tiny card? I am sure there is some simple way but I cannot see it!!!!
Hi Phil1946,
welcome to Questions & Answers..:smileyhappy:
To remove the micro SD card gently push the card in slightly & it should pop out enough for you to be able to place the tip of your finger on & slide it out, if this does not happen & you cannot remove the microSD card, contact customer support..
Do not try a remove the card by force or you could damage your reader..:smileywink:
Not got the T1 but with the PRS-650 you press the card down and release.
Hi Phil1946,
