DSD files and SRS-X9 : How does it work ? natively or via conversion ?
namsoro
Explorateur
Hello,
I do have another single question :
- How does SRS-X9 read the DSD files ? natively or via PCM conversion ?
because when i connected it to my macbook pro 2011, with Audirvana : the caractéristiques of the SRS-X9 as a DAC is limited at 192 kHz while Audirvana shows the DSD 128 and other type of DSD file in not accessible mode.
Thanks in advance.
1 RÉPONSE 1
profile.country.FR.title
Souleyman_M
Explorateur
Hey namsoro,
You should ask your question on the English forum. Its users will be more likely to help you for what you need: https://community.sony.co.uk/t5/english-community/ct-p/en
Good luck! :wink:
