XR65-AJ80 stereo/multichannel sound lost on web apps (iplayer, C4) when skipping
newyankee
I am wondering if anyone else has noticed the following issue.
When playing content on the UK catchup services apps (and others that use the HbbTV/web app scheme) with multichannel sound or just stereo: Sound is fine when played from the start of the programme. However, when fast forwarding or rewinding, sound reverts to mono. This is regardless of the output used (TV speakers, headset, HDMI ARC, optical out).
I have already contacted sony support at the beginning of December 2023, exchanged 100+ e-mails. I had a service technician sent out to replace the mainboard with no effect (surprise!).
I have begged that this issue be forwarded to software engineering. All with zero success.
What else can I do? Yes, I have already added a Chromecast with google TV, so that I now have 2 google TVs in one.
12 REPLIES 12
newyankee
@Anonymous
  1. Please read the full thread. The sound issue is present regardless of DNS/VPN, IP home country. This is not internet service related. It is identical on any web streaming
  2. Please don't go down the route of blaming the customer. It is not always the customers' fault
And sorry, I can't refrain from commenting your suggested solution with the following. You might as well recommend that I refrain from using a SONY TV.
Anonymous
Not applicable
Hey @newyankee
I'd recommend in that case that you contact Sony support team again
anth1234
Hi
Did you get this fixed?
I have exactly the same problem as you just skipping 10 seconds make the sound mono.  I think pausing it also does the same.  Amazon fire stick does not have the problem.  I have a 75" X90 so not cheap.  Just finding a lot of bugs in the software starting to wish had got a TV from another manufacturer...  Still trying to find the cause of the lip sync problems in Netflix...  The mono sound is a really big problem if you have a centre channel.  Its really obvious that its mono.  Not checked if the same problem with the built in speakers.  Currently using a Denon X3800.
Can an actual software dev look at this please.  I work as a software developer and I have tried every setting nothing works.  Its clearly a bug in the iPlayer versions used in some Sony TV's.  Resetting to factory settings never fixed it.
Thanks
Anthony
