Boycecheese
WiFi constant drop
KD-55XE9305 Running lastest software update, released May this year I think. Ever since, the WiFi connection constantly drops then reconnects. All the time. Anyone else?
3 REPLIES 3
Carolina13
Me too
rooobb
sewellpaul77
I've the latest install (6.6520), which upgraded to Oreo and have the same WiFi problem. It seems to be worst when trying to use Netflix. So I don't think that build solves the problem, of anything I think it causes it!
Are there any reliable fixes to try? So far all I've found on other posts are suggestions about using a wired connection instead of WiFi which is not feasible for me. Also suggestions that having multiple routers can cause an issue. I don't buy I do have a Sonos bridge and a Hive hub; in wondering if the TV sees those as routers maybe?
Thanks
