Hi my humax box packed up and I purchased the Manhattan SX but i cant seem to setup the IR Blaster like i did with the humax, the Manhattan SX is not recognised if i type it into the search feature. Does anyone know if there is an equivalent/alternative model i can use. Looking back i should have purchased a freesat tv
Hey, @cjd1965 The model seems to be incorrect, can you confirm it using that: Where to find the model name and serial number?
Hi SaturoGojo, your correct it is KD49XG8196, thanks
Unfortunately, if you can't find your Manhattan SX there, then it's not supported by the TV.
