Sony Bravia KD-55XF9005 TV Netflix issues.
Blumine1818
When using Netflix, the TV freezes and reboots after a few seconds of video playback.
I'm using a wired (powerline) connection, although I could use wifi.
2 ANTWORTEN 2
Pascale_F
Moderator
Hi Blumine1818,
Please check you have the latest firmware installed (v6.5603) on your KD-55XF9005. If you have, it might be worth performing a reset or a Factory Data Reset.
Thanks,
Pascale
Blumine1818
Hi Pascale
Since my post, Netflix playback is fine.
I shall keep an eye on it and reset if necessary
Thank you!
