Has anyone used a Samsung soundbar with the A95L and can comment on whether there's any compatibility issues or lip sync issues please? I have the Samsung Q990C and want to know if it will be OK with this TV.
A95l out of sync with Samsung q990c sound bar.
Issue is seen after a program is paused or watching a recorded program from Virgin box
Anyone else seen this and suggestions to solve. Thanks.
Hi @SteveKelly, firstly check that the TV is running the latest software version. You can also try a different HDMI port, optical or different cable and see if the problem persists or not.
