2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
BHolla47
So I purchased a Sony W755c TV and after assembling the TV stand I've found that it leans dangerously forward, like it's going to fall over at some point. So I've reassembled the stand a couple of times and unless I'm doing something wrong then I don't know why it's still leaning forward..
Anybody had the same issue? Or know a fix?
Everything is screwed in perfectly I just have no idea why this is happening 😞
rdlowry
@BHolla47 Do you have a picture? I've got the same TV and don't have any issues with the stand.
BHolla47
@rdlowry I've got some pictures but not sure how to post them on here.. Do you know how?
BHolla47
rdlowry
@BHolla47 That definately doesn't look right, for a second I thought you had it the wrong way round... It should sit as shown in this picture http://img1.lesnumeriques.com/test/10/10981/kdl-43w755c_1600_04.jpg Did the screws go in ok at the back?
BHolla47
@rdlowry Really? That's how it's supposed to be set up according to the box and the instructions.
gmh1988
the stand is definitely correctly installed, can't comment on the lean though, I have the X85C and it barely leans forwards
ZombieFried777
It looks the right way round with the bar bit of the stand coming across the front. But yea that looks like it's leaning over a quite a bit. I wouldn't be happy with that either. Maybe get in touch with Sony.
danielbeyzade
They will most likely say to do a factory reset to resolve the issue!!!!!!!
BHolla47
@rdlowry All the screws are where they should be and screwed in as tight as possible but it still seems a bit loose at the bottom. Bearing in mind this is the replacement for my first TV of the same model I think it might just be an issue with the 43" model.. Unless I'm doing something wrong but I don't think I am
