Hi Smithee,
Is the TV you have the 55UF860V?
Quick questions, as I may go the same route as you;
1) Does Plex work well?
2) Netflix and Amazon Prime both good? And in 4K?
3) Does it have BBC iPlayer, ITV Player, All 4, and 5 Player?
4) Is the picture good on both Freeview SD and HD channels?
Thanks.
@andrewsoong I did your method to get SONY Select off and Featured apps, it worked!
So I tried to see about getting them back on, and only the Shelf puts back the Featured Apps, I cant get the SONY Select to come back. I can accses it through the settings-apps-SonySelect-open. Just cant seem to get it back on the Home screen. Do you know how too? Its not that important, but would like to know for future .
Hmm not sure. I'd have thought doing the same as the featured apps part would work. If not I imagine a factory reset would if you're desperate.
Also I bet any time Sony push an update it puts them all back.
Regarding navigation in the browser and Google Photos.
I've found that some of my various controllers, airmouse, BT keyboard, Sony TV remote and One Flick remote don't all work for all navigation requirements.
I'd be having to use a BT keyboard touchpad to scroll and the TV remote for some other navigation functions.
The M1 airmouse would show a mouse pointer but the TV didn't respond to OK button clicks.
The answer seems to be to use the TV Sideview app in mouse mode, the TV responds as expected and I'm able to navigate around web pages and Google Photos relatively easily.
Has anyone managed a screenshot with the PWR/VolDown combination, or is there an app that works for the TV?
quick questions, as I may go the same route as you;
Yep the TV has 'smart share' and it found my movies and streamed fine..
I dont have the bandwidth yet for 4K but both work well
Only iplayer and 5 - so no itv or 4 - i used my Xbox for these but i guess i might be an issue if your looking for them.
HD is great - SD not so good, but on the Sony SD suffered a bit - its a case of weighing things up - my main need was for 3D to work and its so much better, like night and day and the 2D to 3D is good. The interface is fast, but simple. So it feels sligthly less classy than the Sony, but in operation its a joy to use - also simple to switch from Freeview to Satellite in the guide.
Hope that helps..
Andy
- as a side note, the stand is not silver, its a brass type colour but is actually rather nice...
Thanks Smithee - I really do want ITV and All 4, so it might not be an option unfortunately.
Do I take it that the Sony firmware update, due 17th, still hasn't been released?
Does anyone have any current news on this?
I noticed this morning that there was an explanation mark next to my network symbol... but I know the TV is connected (wired) to my fiber broadband! Not a big issue really, because I am still online with the unit, just want to know why it is there?
I had the same issue this morning connected via WiFi.
very strange
