@John1950Hitchin wrote:@hextablephil For me 12 weeks without Football is a real plus.
I think you forgot Euro 2016
Isnt there football in the Olympics too?
@Risc0n@Anonymous It's not sport unless it's powered by carbon. Kicking a bit of plastic on a bit of grass and then getting overexcited is not my cup of tea. But it's good that we are all different, just have a look here to see that.
I rang the fabulous Sony helpline and my issue has been escalated. I was asked to send in photos as evidence of the clouding appearing on the screen and managed to capture it on dark and light screens and its deffo getting worse. It's clearly not an input issue as i even captured it on the home screen and within the Sony apps. However i was extremely worried when the guy on the phone said the "experts" he was escalating it may say it falls within normal operational boundaries!
What the hell???
How can a screen that is developing patches all over it be normal operation!
I will be calling again today to find out the progress and will post back on here.
Appologies for not replying sooner, I missed your post
In regards to finding the activation code for SEN on your TV, please see the following thread for instructions:
https://community.sony.co.uk/t5/televisions/registering-a-tv/m-p/2136954
It seems the WiFi issue is more widespread than what it looks like on this forum just take a look at Sony's Facebook page and you've guessed it "contact support see what they suggest"
All refer to the OS being the issue poor guys though no one at support has the heart to tell them that due to the football and Olympics we're all going to be waiting a long time for any issues to be fixed
I didnt say that there definately wont be an update during the Euro2016 - however i think its unlikely. You mentioned previously that you thought this was rubbish. However i have to disagree with you on that, simply because I think that is the most responsible thing to do. As others can probably attest to, sometimes a firmware update can have unintended consequences. Theres potentially 100's of thousands all complaining at once if a failed firmware was released - and rightly so.. Same rule applies on not updating on Friday... Do you see where im coming from here? I may be completely wrong and Sony does release an update!
Anyway, there is almost a month between Euro and Olympics - perfect opportunity for an update.
Now onto your problem - yes there seems to be some people having wifi issues. Have a look at this thread to see if it helps:
https://community.sony.co.uk/t5/televisions/android-tv-wifi-and-ethernet-issues/m-p/2147686
Also, have you tried using an ethernet cable - even as a test? Could this be a work-around solution until such time its fixed? Unknown if you have tried - but sometimes a factory reset can clear problems ?
@Anonymous Apologies if I sound like I'm ranting it's nothing personal in the slightest just after this update to loose a somewhat fundamental feature of the set is a absolute shambles
I've disabled WiFi aswell as Bluetooth due to my touch remote just locking up I don't really see the point of hoping that it works everytime Ethernet with a set of powerline adapters could be a option but I'm holding out until this mystical update comes along and I'll do it through USB
Like I say nothing personal in fact I feel quite bad for you being in the firing line as Sony's social media team are quite useless where as you keep plugging away trying to offer a resolution.
Just get us that bloody update!
Where did you hear about the update? No update available on mine.
