2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
djadrianc
You probably will have to delete the Google account but you can always
re-download the purchased apps at no extra charge from Google
cozzykim
The account will only be deleted from the TV of course, and can easily be reinstated.
matt2807
Could you please give me a brief overview of how you play your videos over your network?
dspencer999
The thing is that I use Plex all of the time, and from what you say, the only way to log out of Google will be to delete the Apps I've purchased, all be it temporarily.
Hopefully the next firmware update will sort out the speed!
Shalendran
Click on the app 'video'. You should now see 'folders and devices'. Now if you click on 'devices' you should be able to see the network hard drive. A PC connected to the same network would also be visible here. Now click on the device and go to the directory 'videos'.
Next go to the 'By folder' directory and navigate to the desired folder.
Cluck on any video to play the same.
I hope this helps.
Stevevalo
That's August out of the way, still no update...
theshamelessmanc
9 months into the 2015 flagship SONY BRAVIA Android sets and still no cure for all the bugs and what not!
No listening to the cries for help and no updates on the updates.
Will be interesting what SONY have up their sleeve over in Berlin today! I wonder what they will announce... maybe the new 2016 Bravia's, minus all the bugs because they learnt from their mistakes with the 2015 sets ?
https://community.sony.co.uk/t5/blog-news-from-sony/ifa-2015/bc-p/2007714#M407
profile.country.SE.title
mrcodec
I have contact with the swedish support team and they are investigationg
the problem thoroughly.
Mvh
Patrik Andersson
LinkedIn
Twitter
Instagram
Edited - removed personal details - Fran_M
mrcodec
I have contact with the swedish support team and they are investigationg the problem thoroughly.
andrewsoong
Wouldn't surprise me if they announced they were pulling out of the TV market after their latest effort!
