UKPiglet wrote:Peter,
The lip sync problems continue after a full factory reset and full set-up from scratch.
I'd love to edit and save a channel list - however without any instruction manual for the set I've not found a way of doing either.
I now have a family set where I cannot see any way of removing channels I'm not happy to be seen by my kids.
Please can you help with instructions on how to edit the channel list?
Unhappy owner of a Sony KD55X9305
Ditto with the 49" model... The 'channel' menus are an example of ridiculous levels of incompetence... The satellite tuning makes its own mind up and adds/subracts channels at will! Freeview is little better.
I've even tried saving my channel list - editing it in the (apparently amateur-built) application, factory re-setting the TV then 'loading back' the edited channel list onto a basically 'blank' TV.... It still seems to be 'fond' of 'perv-vision' as the set adds this filth (which I REALLY don't want in my home!) back and just won't store the channels I want as I want them on my TV.
Just got the KD55X8509C and connected it to the CT380 soundbar using HDMI(ARC). All was working fine, with soundbar switching on as soon as TV was switched on. However, last two days, the soundbar doesn't switch on straight away. There is a 15 second delay before it switches on. Has anybody else experienced this problem and if so, can it be resolved?
I have done the usual, reset soundbar, TV and disconnect and reconnect, but still having the same problem.
Hi UKPiglet and Caledonian,
Best way to manage the channel list on your TV is to export the channel list to an USB Stick (Settings > channel set-up > digital set-up > technical set-up > program list transfer) and then using the Sony Editor on your PC to delete unwanted channels. Then save this list an import it back to your TV. Please use an empty USB stick formatted with FAT32 to save the program list.
To stop the TV looking for new or changed channels please disable Service replacement in "technical set-up".
Hope this is helpful
Peter
There is a way to edit the channel list to remove 'undesirable' according to taste of course, channels. It is buried dwon in the settings menu. I can't recall off the top of my head but it really is not too difficult to be honest. I went looking for it as I am not interested in the various 'XXX' channels, too old now
I soon found it. What I will say is that it is tedious and time consuming and annoyingly has to be done all over again when you do a standard channel rescan. Which Freeview requires every 6 months or so when they get new channels 😞
I'm sorry I can't be more specific for you 😞
@Randy_Rockhard wrote:Hi UKPiglet and Caledonian,
Peter
Thank you for this Peter
Is the SONY editor purely a text editing program? I am presuming it is a Windows compatible piece of software? I do not use Windows only Linux but I do have access to plain text editors and can save to multiple formats. I would imagine it would be a standard format being as the tv operating system is Android (built on Linux)?
Peter
I'm afraid Peter this simply does not work!
If you'd read my previous post properly you'd realise that I took the time to save my channel list, factory re-set (and power cycle) the TV then restore the channel list to an 'empty' TV...
Yes... "Service Replacement" IS off...
But still the set actually deleted a (satellite) channel and replaced it with another while I was watching the news. More usually, accessing the 'guide' from satellite will cause the channel you're on to be deleted from the list... The system is seriously unstable!
As for the 'Sony Editor' - which member of the community wrote and provided it? For you cannot seriously be touting this as a piece of professionally produced software? Nor, for that matter, the set's own editing facilities as adequate; and therefore the kind efforts of an amateur as any kind of substitute for simple 'fitness for purpose'.
@kevfarme wrote:Is the SONY editor purely a text editing program? I am presuming it is a Windows compatible piece of software? I do not use Windows only Linux but I do have access to plain text editors and can save to multiple formats. I would imagine it would be a standard format being as the tv operating system is Android (built on Linux)?
It's Windows, pretty basic and very fiddly... What it 'edits' is an XML file...
You will spend HOURS trying to edit your channel lists with it; and I'm not the only one to find (where's Manuel?) that it just doesn't solve the problem with the satellite tuner randomly resetting itself!
Additionally - it doesn't allow you to edit channel names ( as you might need to with regional variations) and when transponders change, well basically you'll be back to square one! No facility to edit or add new data! - Somebody 'out there' has obvoiusly been kind enough to create this and fair play to them; but as I said, it's not a professionally produced piece of software and basically doesn't solve the problem!
