2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
gunit1978
@Anonymous Could you look at my issue a few posts up, do you know if its a bug or needing tv swapped over?
Thanks in advance
Anonymous
Not applicable
@gunit1978 not seen your issue, but if it continues, i would probably factory reset the tv to clear out any issues.  I dont suppose this started after installing an app or a setting change or....?
If its a hardware issue, the tv normally flashes/blinks its LED in a sequence
gunit1978
Thanks for the reply, I havent installed or changed anything for a few days, I've only had it a couple of weeks and already done FR 3 times lol
At least the LED isnt flashing I suppose thats one thing :slight_smile:
Thanks again.
haribo411
Hi all, newbie here. I was searching for some info on my new TV and came across this thread which has really worried me.
I've just ordered a curved 4k TV which looked great in store. it's the KD55S8005CBU.
Based on what I'm reading here I'm headed into a world of pain. My current LG has never had a single issue and I'm not techie enough to deal with all the things you guys are discussing. If the lip sync's from using my Tivo I'm in for trouble from the wife.
Am I best just cancelling the order and going for a Samsung etc?
Thanks, Chris
Al_Charles
@haribo411 It would not be fair for us to tell you what to do, read the forum then deside.
Has anyone else got problems with Netflix
theshamelessmanc
@trickytree1984 what sort of probs?
I get an issue (not limited to just Netflix) where when I press the dedicated button on the remote, a box pops up to tell me I need to connect to the network.
The telly is wired in, I can connect to any online content provided I go through the Home menu and select the relevant app. Sometimes the Netflix button works, other times the box pops up! I am thinking it may be something to do with the exclamation mark next to the network symbol!
To the missus annoyance ( love annoying her) just tried the Netflix....... Its just hanging, like loading forever! is this what you mean? Hurry with the answer, I think shes going to kill me because she wants to watch Dr Foster lol
pepitoe
Yes I had an error message yesterday but going into More Details and choosing the Reset option seems to have fixed it.
UKPiglet
Yes, same issue here last night. The machine didn't think it had any connection to the internet despite being on a wired connection.
A hard reboot and it was working again.
Hanging on until the next update. If things are not significantly better I'll be having a long talk with John Lewis.
gunit1978
@UKPiglet I've had that a couple of times too, I am not even a month into my 90 days, I really don't want to take it back as I love the picture quality on it but all the niggles and the not turning on issue are beginning to get annoying
