Sony a6700 Firmware Updates
e.okorie.2020
Are we to expect any new firmware upgrades for the Sony a6700?   There seems to be no movement on any new APS-C cameras so I would hope Sony could at least help improve the software and add/enhance the features in the camera.
A wish list:
  • Custom Setting Names: Rename Memory Recall slots (1, 2, 3 & M1–M4) to specific labels like "Street," "Astro," or "Portrait."
  • Vertical Shooting UI: Auto-rotate exposure data (ISO, SS, Aperture) on the display when shooting in portrait orientation.
  • Settings Sync: Named profile backups via the Creators’ App for seamless synchronization across dual-body setups.
  • Intervalometer + Bulb Integration: Enable the "Interval Shoot Func" to trigger the specific exposure durations set in the "Bulb Timer."
  • Red "Night Mode" UI: A dedicated red-light theme for all menus and overlays to preserve night vision during astrophotography.
  • Shutter Shield: Option to close the mechanical shutter on power-down to protect the sensor from dust during lens changes.
  • Pre-Capture: A rolling buffer to save frames captured just before the shutter button is fully pressed.
  • "Auto" Subject Recognition: A unified AI mode that automatically detects all subject types (Human/Animal/Vehicle) without manual switching.
  • In-Camera Focus Stacking: Internal processing of bracketed shots into a finished composite image.
  • Shutter Angle: A 180° option to maintain consistent motion blur across various frame rates in hybrid workflows.
  • Named Film Recipes: Expansion of the "Creative Look" system to allow saving and naming custom recipes with grain and color chrome effects.
  • In-Camera Image Compositing: Provide the ability to merge captured brackets into a finished file (Focus Stacking, HDR/Exposure Blending, and Multi-Exposure) directly in-camera.
  • Sweep Panorama: Re-introduce the in-camera panorama stitching feature that was present in previous APS-C models but is currently missing from the flagship.
  • Expanded Grid Line Options: Beyond the basic "Rule of Thirds," we need customizable grid lines (Golden Ratio, Square/1:1 for social media, and Cinematic 2.35:1) available as a standard feature, rather than a paid "Pro" license.
I use the a6700 extensively for professional work. In 2026, it can no longer be viewed as just a hobbyist camera; its AI tracking and image quality are frequently used on paid editorial and commercial sets. While I can overlook hardware limitations like a single card slot, the lack of software support for your APS-C flagship is disappointing. It feels as though this camera is being left to rot until a successor is announced. It has been over two years since the last update, which was merely for 'stability.' While stability is appreciated, many professional users feel left behind. I know Sony can do this; the hardware is capable, but the software needs to catch up to the professional standard of the shooters using it.
0 REPLIES 0
