Northern Lights trip to Norway next month with my dslr-alpha100. Any advice on settings, colour balance etc?
Hello tonyhaseler - welcome to the Sony Forums
For your trip (sounds exciting!), I would advise that you do the following:
I have never had the priviledge of seeing them myself, however I have heard people say that because they are constantly changing natural phenomenon, you should be prepared to have quite a few attempts at it before you get it right!
Enjoy your trip,
Simon
One tip I would add to Simons post is more general advise rather than settings. Keep a few batteries handy since in colder conditions, battery life is reduced.
Keep them in an inside pocket until required. I was out in Sweden a few weeks ago with an average temp of -18 degrees C and was only getting about 30 mins out of my battery until I kept them up to a decent temp by putting them into an inside pocket.
