LA-EA4 and stabilization
hi, I wonder if I use this Tamron SP 24-70mm F/2.8 Di VC lens with a LA-EA4 adapter on a A7s, would still recognise de vibration compensation of the lens? thanks!
1 REPLY 1
Marino.Manolo
Hi @sin2numeros,
read the answer from Heather S, (bhphotovideo's staff).
Q&A Section, here: http://www.bhphotovideo.com/c/product/845351-REG/Tamron_SP_24_70mm_f_2_8_DI.html
will this lens work with the sony LAEA4 Adapter and still retain autofocus and stabilization.
Alex B on Oct 28, 2014
BEST ANSWER: Yes, so long as you are using a Sony A-Mount lens, including A-Mount lenses from third party lens manufacturers such as Tamron, you will retain autofocus and image stabilization using the LAEA4 adapter.
Manolo
