Does anyone know if there is a firmware update for the A550, if so do they know the web address. Regards Gerry1954
Hi Gerry,
You will find all updates and other support for your A550 on the Support Pages for your model here: -
http://www.sony.co.uk/support/en/product/DSLR-A550
Unfortunately, there seems to be only software updates.
