USB C to 3.5mm adapter problem
Drummernaught
Hi, I'm using an Xperia 1, I've just tried to connect my wired Sony EX650LP earphones, which have a line in mic.
Using a USB C to 3.5mm adapter, I was able to hear audio perfectly fine, however the microphone is just not working at all.
I noticed I'm able to use the phone's microphone whilst the earphones are plugged in though, which makes me think it's maybe a coding error?
Any suggestions at all would be great, if anyone had this problem, what was your solution?
Thanks.
3 REPLIES 3
IamNic
Hello @Drummernaught,
which adapter do you use? If it is a TRS adapter while the headphones have a TRRS jack, observed behavior would not be surprising.
- Nic
Drummernaught
Hi, thanks for replying.
I did a bit more searching and found out about my headset being 4 pole TRRS, and have purchased a TRRS adapter, was this correct?
IamNic
in this case it should work. It could still be, that the adapter is broken. Have you cross-checked with another adapter or know for a fact the adapter works (on another phone/tablet)?
- Nic
