Ladeanzeige XP 1V per LED
Fintsy
Wie kann man beim Xperia 1 V den Status der Ladeanzeige per LED (rot=lädt und grün=fertig geladen) wie bei Xperia 1 III anzeigen lassen?
Danke für eine Info
How can I display the status of the charging indicator on the Xperia 1 V via LED (red = charging and green = fully charged) as on the Xperia 1 III?
Thanks for an info
Marino.Manolo
2 REPLIES 2
Marino.Manolo
Fintsy
Thanks 4 the unfortunately bad news to me,  I Iiked this quick info with my former version III, probably should have waited for VI, iV I had  skipped because of the temperature problems.
Many THX again for your precise Info, RGDS
